3rd party call loggin software
Sep 18th, 2007
dear folks,
what all configuration is required on callmanager to integrate callmanager 4.2 with third party call logging software(proteus CTI data).also when i configured call logging software its not able to reach callmanager i checked the port (1050) is also correct as this is the default option.
thx for your support.
regards,
rodoneal60 Tue, 09/18/2007 - 10:44
You might try including the Proteus CTI server IP Address in the Callmanger HOST file list. The file is located under the etc directory.
sandeep pokhriyal Wed, 09/19/2007 - 03:54
thxx for your reply.
can you please suggest some docs for configuration on the call manager side to integrate with third party call logging software.
regards.
