Change configuration
orlandino15
I have a PIX 525, erase configuration with "write erase" after boot the follow message"Cryptochecksum (changed)" displayed, and I don't have prompt for continued the configuration. What's ?
amritpatek
Level 6
Level 6
Try the following commands in configuration mode:
Pix#config t
Pix(config)#ca zeroize rsa
Pix(config)#ca generate rsa key 1024
Pix(config)#ca save all
Pix(config)#write mem
Pix(config)#reload
That should fix the problem, but in order for the key to generate, you need to ensure that the PIX has a host name and domain name configured. If you need to do that too use these commands:
hostname xxxxxx
domain-name xxxxx.com
