Hlog button not working properly
Answered Question
Sep 18th, 2007
I have a IP Phone 7941 that I placed into a hunt group. All the other users hit the HLog button and the "logged out from hunt group" message disappears. This one particular phone shows the message "logged out from hunt group" whether it is logged in or out from the hunt group. The CME shows it as logged on but her display does not change. Any ideas?
Thanks.
Correct Answer by paolo bevilacqua about 9 years 8 months ago
Ok, then you should download latest firmware for the phone, copy all files on the router, make them available with "tftp-server" command, reset phone to factory via keypad sequence (power-on with # pressed, release when led flashes in steady pattern, press 123456789*0#).
Overall Rating: 5 (1 ratings)
paolo bevilacqua Tue, 09/18/2007 - 07:40
  • Hall of Fame,
    Founding Member
By chance this extension is under an 'm' button from an ephone? Strange things happens when mixing hunt-group and shared lines.
agonza07 Tue, 09/18/2007 - 09:51
Not too sure what an 'm' button is but there are no shared lines. I'm just starting to understand the commands for the CME, but I even created a new phone and added it to the hunt group and it works good. It seems like it is just that phone, specifically that button that does not update the display but does update the CME.
Correct Answer
paolo bevilacqua Tue, 09/18/2007 - 13:58
  • Hall of Fame,
    Founding Member
