RDBMS Synchronization with a .CSV file
Sep 18th, 2007
Good morning. I am trying to create a testable .csv file that I can import into our ACS on a prescheduled basis.
Here are my questions about this process:
1. Do I need to use the PASS_Expire action or is there a STOP_DATE? I have looked at the codes and didn't really see one.
2. Is there a way that I can extract a copy of the dump.txt or get my actual database exported to a different system?
3. What are the group's recommendations on synchronization? Are there some lesson's learned I should look out for?
Dwane
2. You can export your data into flat files via command line and then import on the next system the same way but I dont see why you would want to.
3. Use the internal replication if you're using the internal database.
If you're using external databases like sql or oracle this is a moot point, just do table dumps and import.
can you help me add vendor UDV and attributs to ACS.
I tried it it showing me UDV, but getting a error RDBMS report for one attribut.
when v3 is integer
Error: ACS 'ACS_A1' Action failed [SI=6 A=352 UN="" GN="" AI="" VN="Login-Service" V1="2011" V2="10" V3="integer"] Reason: UDV VSA error - User Defined Vendor/VSA operation failed (VSA name not unique)
when v3 is string
Error: ACS 'rdevid-4eafe3cf' Action failed [SI=6 A=352 UN="" GN="" AI="" VN="Login-Service" V1="2011" V2="7" V3="string"] Reason: UDV VSA error - User Defined Vendor/VSA operation failed (VSA name not unique)
actually i am doing it for H3c.dct  it is for 3com.
Below is the file which i used.
SequenceId,Priority,UserName,GroupName,Action,ValueName,Value1,Value2,Value3,DateTime,MessageNo,ComputerNames,AppId,Status
1,0,,,350,3COM-H3C,AUTO_ASSIGN_SLOT,2011,,,,,,0
2,0,,,352,h3c-User-Access-Level,2011,26,integer,,,,,0
3,0,,,352,Administrator,2011,3,string,,,,,0
4,0,,,352,Manager-(write),2011,2,string,,,,,0
5,0,,,352,Monitor-(read),2011,1,string,,,,,0
6,0,,,352,Login-Service,2011,5,string,,,,,0
7,0,,,352,SSH,2011,50,string,,,,,0
8,0,,,352,Terminal,2011,52,string,,,,,0
9,0,,,353,,2011,221,IN OUT,,,,,0
10,0,,,355,,,,,,,,,0
Also please let me know how can delete the UDV if i want to. i tried procedure mentioned in user guide but failed.
