Time on CallManager 5.1
Sep 18th, 2007
I just did a new install, but I have had other issues that I have been trying to fix. So now I have the system stabilized, but my time is off by 3 minutes. I know if I change my time server, I have to reboot......but if I manually change the time, do I have to reboot all my nodes in the cluster. The documentation doesn't mention it for changing the time manually, but when you look at the time settings on the server, it says you will have to restart....I just want to know if I can change the time, reboot the phones and get by without rebooting the server. Because as with a lot of things Cisco, if I mess with this and reboot the server, then I have to go through another process of getting something else working
Anonymous (not verified) Mon, 09/24/2007 - 10:10
For changing the time settings.Go to OS Administration in the server -->Settings-->Time . You need not restart the CCM server
