proceed only https and prevent any http on CSS
Sep 18th, 2007
I have to following config:
service SSL-EtradeTest
type ssl-accel
slot 2
keepalive type none
add ssl-proxy-list SSL_Proxy
compress enable
active
service WEB1
ip address 172.20.2.21
compress enable
slot 2
active
service WEB2
ip address 172.20.2.22
compress enable
slot 2
active
!*************************** OWNER ***************************
owner WEB
content SSL-Content
vip address 172.20.2.30
add service SSL-EtradeTest
protocol tcp
port 443
active
content WEB1-Content-HTTP1
add service WEB1
url "/HEN/pushlet/"
protocol tcp
port 9080
active
content WEB2-Content-HTTP1
add service WEB2
protocol tcp
port 80
url "/Trading/*" active
!*************************** GROUP ***************************
group WEB
add destination service WEB1
add destination service WEB2
active
CSS should not process http request send to it. It should process only
https requests.
Any idea please.....
Hasan
Gilles Dufour Tue, 09/18/2007 - 23:10
  • Cisco Employee,
Hasan,
you can create a content rule for port 80 (HTTP) and use a redirect to send the traffic to HTTPS.
But you have to send your decrypted traffic to a different content rule : ie port 81.
However, if a user does a port scan and find port 81, it can bypass your HTTPS rule and access directly the port 81 content rule.
So at the end you will still need the ACL.
Gilles.
