Portal Customization storage location and replication on ASA 5540 SSL VPN
When you customize a clientless VPN portal, it allows you to customize graphics and other elements. Where on the system are these stored? A sh flash command reveals nothing. I want to ensure that the customized elements are saved and are being replicated to the standby host. This is for 8.0(2)
amritpatek Mon, 09/24/2007 - 11:40
By default they are stored in running configuration, but you can export them as templates.
The customization you run on your webvpn portal can be exported/imported in ASDM, under:
'Configuration --> RAS VPN --> Clientless VPN --> Portal ---> Customization'
