Using the "no" form of a command, help please.
kcaporaso
I created a static nat that has locked me out of my asa 5505 from my network, great right? Command was:
static (inside,inside) interface 192.168.1.30 netmask 255.255.255.255
I'm trying to get rid of this using:
no static (inside, inside) interface 192.168.1.30 netmask 255.255.255.255
from the console, but it doesn't seem to like the "no" syntax.
How can I remove this static nat using the console?
Thanks much!
ASA/C2# conf t
ASA/C2(config)# static (inside,outside) interface 192.168.1.30 netmask 255.255.255.255
WARNING: static redireting all traffics at outside interface;
WARNING: all services terminating at outside interface are disabled.
ASA/C2(config)# sh run static
ASA/C2(config)# no static (inside,outside) interface 192.168.1.30 netmask 255.255.255.255
ASA/C2(config)#
a.alekseev
Level 7
Level 7
look at the configuration "sh run"
use "no" in front of the statement which you are going to delete.
I feel like that's what I'm doing...
I am typing, at the console prompt, the following command:
The consold fails it with the following error:
Invalid input detected at '^' marker
where the '^' is pointing at the 't' in static.
Am I missing something here?
ASA/C2# conf t
ASA/C2(config)#
Thanks very much! That did it!
