PORT 1024 UDP & TCP
Answered Question
Sep 18th, 2007
Does anyone know what this port is used for? I looked it up on IANA's list and all it says is reserved.
Correct Answer by dgahm about 9 years 6 months ago
Omar,
It seems to be one of those well known ports that is not so well known, and is used by a variety of apps, including the MYDoom virus. Here's one list:
RAT:NetSpy, Jade, Latinus, Randex,
W32.Mydoom, Lingosky
http://www.bekkoame.ne.jp/~s_ita/port/port1024-1199.html
Another reference:
http://www.auditmypc.com/port/tcp-port-1024.asp
Please rate helpful posts.
Dave
Overall Rating: 5 (1 ratings)
Correct Answer
dgahm Tue, 09/18/2007 - 16:56
  • Blue, 1500 points or more
Omar,
Another reference:
Dave
ojdecastro Tue, 09/18/2007 - 18:10
Dave
Thanks for your reply and the references.
Omar
dgahm Tue, 09/18/2007 - 18:30
Omar,
You are welcome. Don't forget to use the pull down menu to rate posts that helped you out.
Regards, Dave
ojdecastro Fri, 09/21/2007 - 08:17
I would love to acknowledge your assistance but I've looked and I just don't see an option to rate the post. Please advise.
Omar
