Advice For Bridging LAN over the Internet
Sep 18th, 2007
I've been tasked with bridging a remote office subnetwork over a cisco 871 through their ISP back to a Cisco 3725 at main campus. From the cisco 3725 it needs to bridge back to a bluesocket brand gateway to be routed. The requirement was that the bluesocket gateway needs to be in the same subnet as the remote office subnetwork. I know that this is not ideal...
Anyway, what tunneling protocol should I be looking at to bridge this back? bridge-groups over GRE?
Thank you
paolo bevilacqua Tue, 09/18/2007 - 14:17
  • Hall of Fame,
    Founding Member
I've used with the bluesocket product. It does not require that the devices it controls are in the same subnet. In configuration, there is a button where you click 'add remote subnet', enter the parameters, and it will control anything from that subnet nicely
This will allow you to do a sane design.
loughlind Wed, 09/19/2007 - 05:08
Thank you for the sanity check. I don't administer the bluesockets.. We have a separate group.
To get the bluesocket to work like that, do I need to run PBR on the routers between the remote office 871 and the bluesocket? How do I insure that traffic will pass through the bluesocket?
