Concentrator 3005 ports for router
Sep 18th, 2007
Hello to ALL,
Something got screwed up here. I need to know which ports should be open on a router that is in front of the concentrator ? ? ?
UDP 4500
TCP 10000
Are these right ?
Please help, thank you
fembsen Thu, 09/20/2007 - 02:27
IPSec uses the ESP IP protocol (not port) and UDP port 500 (isakmp) and might use the AH IP protocol.
If you use Nat-T then you need UDP port 500 (isakmp) and UDP port 4500 (originally UDP port 10000). With Nat-T there is no need for the ESP and AH protocols.
Regards, Frank
