CUCME & CUE 3.0.1
i have two issues with cucme and cue
cisco 2821
ios 124-15.T1
Cucme 4.1
Configuration CUE:
call from pstn are forwarded to cue to check schedule programmation. when bussiness hours, the call is forwarded to cucme (hunt group)
the hunt group has three members with final destination (return to cue to play a wav).
cucme is master of clock and cue is synchronized with cucme
Issue 1:
all call from pstn not match the systemschedule. closed hours not hit. only holidays is ok. all call takes open busisnness hours.
Issue 2:
when call is sent to cucme by cue (hunt group)
the caller hear ringback for the first member. if the first member doesn't answer the call (noanswer), the call swith to second member. the caller doesn't have the ringback of the second member but the ip phone of this member ring really. when the call switch the third member, the caller have again the ringback. and final the call reach the final number (audio prompt).
Many thanks for response
