Confusion
Answered Question
Sep 18th, 2007
Hi All,
I am littile bit confused that when SUP-IV is connected in 4507R chassis in both active & redundant slot , only one of the GBIC slot is active on both SUPs. Is it so?
Also, is this IOS dependent ..?
regds,
aman
Correct Answer by ankbhasi about 9 years 10 months ago
Hi Aman,
That is the way it works. This is not IOS dependent. Basically, the restrictions is to use only two uplinks (one each on each Supervisor) are due to the hardware design of the Supervisor. Therefore, this will not be fixed in any new software releases.
You can view this link which will guide you which gbics slots will be active on different sup platforms
http://www.cisco.com/warp/customer/473/177.html#topic2
Ankur
*Pls rate all helpfull post
Overall Rating: 5 (1 ratings)
Correct Answer
ankbhasi Tue, 09/18/2007 - 22:41
  • Cisco Employee,
Hi Aman,
Ankur
