I have a problem with the CRM connector. The Phone number processor of this CRM connector has a window for configuration. This window IS AVAILABLE ONLY when you install the server part of the connector. Then dissapears, or it seems to do so because i can not find it. I have to reinstall the server part to test the patterns which are on the connectors. Is very strange...
If someone can help with some advice, appreciatte a lot.
Thank you very much.
