IPCCX 4.0 Can't Hear IVR prompts
Sep 19th, 2007
I have uploaded the default icd script and am able to transfer calls to agents but i cannot hear the 'welcome' IVR prompt. I am getting some errors in the MIVR log which looks like this
136: Sep 19 11:27:20.757 GMT+400 %MIVR-LIB_TC-6-MSG:: Message=Ctx( /restoreadmin ): Removing duplicate servlet jsp jsp(org.apache.jasper.servlet.JspServlet/null),Exception=null
%MIVR-LIB_TC-6-MSG:: Message=Ctx( /restoreadmin ): Removing duplicate *.jsp -> jsp(org.apache.jasper.servlet.JspServlet/null),Exception=null
147: Sep 19 11:27:21.210 GMT+400 %MIVR-LIB_SERVLET-3-MSG:: Message=path="/restoreadmin" :jsp: init,Exception=null
148: Sep 19 11:27:21.241 GMT+400 %MIVR-LIB_JASPER-6-MSG:: Message=Scratch dir for the JSP engine is: C:\Program Files\wfavvid\tomcat\MIVR_work\localhost_8080%2Frestoreadmin,Exception=null
149: Sep 19 11:27:21.241 GMT+400 %MIVR-LIB_JASPER-6-MMSG:: Module=IMPORTANT,Message=Do not modify the generated servlets,Exception=null
150: Sep 19 11:27:21.257 GMT+400 %MIVR-LIB_SERVLET-3-MSG:: Message=path="" :jsp: init,Exception=null
Abdulbaseer Mohammed Wed, 09/19/2007 - 21:58
Please describe your problem bitmore. Is every thing including prompts are local to ipcc? seems some things cannot be found or duplicated.
charlesgv Thu, 09/20/2007 - 01:48
Hi Baseer,
Yes, everything is local. I am just trying to setup a lab environment. Everything seems to be setup up fine. It is only the IVR prompts that i cannot hear.
Abdulbaseer Mohammed Thu, 09/20/2007 - 22:20
Check weather you have prompts in default directory in CRS admin.
run the debug of your script see if its hitting the prompts.
Try using one of the system prompts if it works then you know your custom prompts are not ulaaw... format try saving promptw with cisco supported format.
