For CCIE Account merge issue
Sep 19th, 2007
Dear all:
Recently I took the CCIE written; however, I found The Cisco do cretae an new account for me, but not merge or add the record into my previous CCIE Profile. And the web site: www.cisco.com/go/certsupport did not have the way to solve the problem. I expect that it was cause by the different test center. So, can anyone provide the suggest to solve it? Thansk for any recommandation.
Overall Rating: 5 (1 ratings)
paul.matthews Wed, 09/19/2007 - 01:41
  • Silver, 250 points or more
You need to log a case and ask them to merge the profiles. I got caught with that as all my previous exams had been with prometric, but I had to do the latest with Pearson, despite giving all the info, it didn't quite fully match up...
Giuseppe Larosa Wed, 05/27/2009 - 22:23
  • Hall of Fame,
    Founding Member
Hello Paul,
I have the same problem and I've just opened a case with certsupport.
When I've created the vue profile there was no way to set the Candidate-ID.
I learned the vue id on the cisco tracking site.(I don't see it in vue web site)
My original CCIE profile is tied to SP id and I cannot change it.
Now there are two records in the CCIE database.
How long it took to have the records merged ?
Best Regards
Giuseppe
Giuseppe Larosa Mon, 06/01/2009 - 10:43
  • Hall of Fame,
    Founding Member
problem solved opening the case.
It took two days.
Best Regards
Giuseppe
