09-19-2007 02:25 AM - edited 03-14-2019 11:36 PM
We've currently got a Call Manager Express installation with Unity Express module (AIM) and BRI NT/ST Vwic cards.
There's an ISDN NT terminator box to which the CCME connects to. There's also a fax which connects to the NT terminator box.
I'd like to stop CCME from answering phone calls made to specific numbers (fax number) e.g we've got a fax number (7654321) and when someone calls the fax number, the CCME picks up the line first.
Suggestions are much appreciated.
Thank you.
Solved! Go to Solution.
09-20-2007 12:55 AM
Hi, you should be able to configure "isdn answer xxx" under bri interface to define to which called number the router answers.
I think that trasalation-rules to reject calls, is not really what you want to do.
A problem may arise if you have did and the fax number falls into that range.
09-19-2007 08:30 AM
I am also looking for similar information. However, I am looking for how to block calls from certain calling numbers. It is likely the same procedure to do both of those configurations.
09-20-2007 12:40 AM
Jfenner,
I've found the following document that might be of some help for you, but didn't resolve my issue:
09-20-2007 12:55 AM
09-20-2007 01:08 AM
Thank you very much bevilacqua,
You did infact resovle my problem !
Cheers
