Renaming Team names in CRS
Answered Question
Sep 19th, 2007
I want to revamp my Teams in CRS. I would like to consolidate and rename some of them and change a lot of members groups. Is there any reason I should be worried doing this? Will this effect anything else? i.e. CSQ's. I am doing this to reorganize the layout of the Cisco Supervisor Desktop.
Correct Answer by Abdulbaseer Mohammed about 9 years 3 months ago
Yes it will take effect immediately. The agents or users have to logout and logback in to see the change.
Good luck. if this helps please rate.
Baseer.
Overall Rating: 5 (1 ratings)
Abdulbaseer Mohammed Wed, 09/19/2007 - 04:19
Yes. My first recommendation is do this after hours. Secondly write down all the info as is b4 making changes.
Lastly document all clearly run by your users, establish a plan for any mishap to be reported back to you and then yes go ahead.
This is very simple stuff, basic re org but can be a pain if you don't do it right.
Baseer.
spotlight41 Wed, 09/19/2007 - 04:24
Do the changes take effect immediately? Will I be able to log into Supervisor Desktop and see the new Teams right away? My users are currently not even using Sup Desktop as of now. This is a brand new installation and I'm just ramping this up. The Teams were set up for me by a 3rd party, and I am now looking to change. In this case, okay to do during hours since they aren't using it now anyways?
Correct Answer
Abdulbaseer Mohammed Sun, 09/23/2007 - 21:35
Baseer.
