3750 port disables
xhackuss1
I have a 3750 switch that is been used as a distribution switch. I have a number of vlans on the switch.This switch is connected to a catalyst 6500 switch through ospf. This connection has been in place for about 3 years now without a problem. Lately, the interface on the 3750 (gigabit port,L3) has been giving me sleepless nights. everyday,the port shuts down and i either have to restart the switch or remove the fiber cable and re-insert it before the link comes up. I am at wits-end. Can somebody tell me what could be the problem and suggest how I can get it fix.
5 Replies 5
pciaccio
Level 4
Level 4
There are several areas to check:
Check your logs to see of any port/interface issues from both sides
Check the port/interface stats for any excessive errors (Both sides)
revalidate your fiber cabling and see that all connectors are snugly in place (maybe someone messed with the cabling).
Do these basic checks and then see what you find... Good Luck...
guruprasadr
Level 7
Level 7
Do you see some Logs in the Switch during this Incident occurance.
Pls provide us additional INFO to help on this Incident.
Best Regards,
Guru Prasad R
Thanks a lot.Below is an output of "show logging"
DSwitch#show logging
Monitor logging: level debugging, 0 messages logged
Buffer logging: level debugging, 114
Log Buffer (4096 bytes):
face GigabitEthernet1/0/26, changed state to up
23:45:51: %OSPF-5-ADJCHG: Process 222, Nbr 10.254.254.1 on GigabitEthernet1/0/26
from LOADING to FULL, Loading Done
23:46:11: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/23,
changed state to down
23:46:12: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/23, changed state to down
23:46:15: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/23, changed state to up
23:46:17: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/23,
changed state to up
1d02h: %OSPF-5-ADJCHG: Process 222, Nbr 10.254.254.1 on GigabitEthernet1/0/26 fr
om FULL to DOWN, Neighbor Down: Dead timer expired
1d15h: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/26, ch
anged state to down
1d15h: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/26, changed state to down
1d15h: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/26, changed state to up
anged state to up
1d15h: %OSPF-5-ADJCHG: Process 222, Nbr 10.254.254.1 on GigabitEthernet1/0/26 fr
1d15h: %PHY-4-EXCESSIVE_ERRORS: Excessive FCS, data, or idle word errors found o
n interface Gi1/0/23
1d18h: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/26, ch
anged state to down
1d18h: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/26, changed state to down
1d18h: %OSPF-5-ADJCHG: Process 222, Nbr 10.254.254.1 on GigabitEthernet1/0/26 fr
om FULL to DOWN, Neighbor Down: Interface down or detached
1d18h: %SUPERVISOR-3-IIC_INIT: IIC Reinitialized
1d18h: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/26, changed state to up
anged state to up
1d18h: %PHY-4-EXCESSIVE_ERRORS: Excessive FCS, data, or idle word errors found o
n interface Gi1/0/10
anged state to down
anged state to up
anged state to down
anged state to up
1d19h: %OSPF-5-ADJCHG: Process 222, Nbr 10.254.254.1 on GigabitEthernet1/0/26 fr
Awaiting our response
Is this fiber? If it is 1000BaseSX, try changing the GBICs - they are terribly unreliable. I was told they use the same laser diodes as in cheap CD players, and they deteriorate with age.
It might be something else entirely, of course, but if you have any spare GBICs it is worth a go.
Kevin Dorrell
Luxembourg
Thanks a lot Kevin. I will try that and see what's up
