LMS up/down notifications
Answered Question
Sep 19th, 2007
Any one can help me creat a notification for UP and DOWN only for all my network?
I can use the OPERATIONALY DOWN notification? and who about the UP notification?
Thank you
Correct Answer by Joe Clarke about 9 years 5 months ago
Yes, you can use the OperationallyDown event. For the UP part, just make sure you also check the Cleared box. When the vent clears (i.e. the object comes back up), then you will be notified as well.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Wed, 09/19/2007 - 08:55
