subnet zero 0, to use or not to use?
ctucker1405 Wed, 09/19/2007 - 10:51
They will usually state whether or not to consider subnet 0 as a valid subnet.
Chris
evanhook3 Fri, 10/05/2007 - 18:17
If they specify use of the command 'ip subnet-zero', then you can safely assume that it is ok to use it. The training material that I was using from Global Knowledge stated that you could not use it, but that is certainly not the case.
