wcs 4.1 tcp port access
Sep 19th, 2007
How can I change tcp port used to access wcs app on nt server?? I have a server used for other apps in addition to wcs and they require port 8080 for usage. I have completed install and currently it is being re-directed from 80 to 443. How can I remove port 8080 from being used if possible??
Overall Rating: 5 (1 ratings)
ericgarnel Wed, 09/19/2007 - 06:35
Windows or Linux?
if linux, look under /opt/WCS4.1/webnms/apache/conf/
edit httpd.conf with the ports you desire, restart WCS
open the ports in iptables, restart iptables
ericgarnel Wed, 09/19/2007 - 06:36
My bad, I did not see "nt server" when I read your post. But there should be a similar file for apache under windows as well.
Trending Topics - Security & Network
