About 7921G too
Sep 19th, 2007
Cannot associate 7921g with 851W with LEAP autentfication. When set autentification to Open - all is ok.
Config from 851w below:
aaa new-model
aaa group server radius rad_eap
server 172.16.1.100 auth-port 1812 acct-port 1813
aaa authentication login eap_methods group rad_eap
dot11 ssid NOC
authentication open eap eap_methods
authentication network-eap eap_methods
interface Dot11Radio0
no ip address
ssid NOC
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
interface BVI1
ip address 172.16.1.100 255.255.0.0
radius-server local
nas 172.16.1.100 key 0 Cisco
user 1 nthash 0 69943C5E63B4D2C104DBBCC15138B72B
radius-server host 172.16.1.100 auth-port 1812 acct-port 1813 key Cisco
In 7921g Security mode set to LEAP at EAS-FAST - the same result. Message on phone - authenitcation failed and nothing in logs at 851 with
debug dot11 aaa dot1x all
debug radius authentication
debug radius local-server client
debug radius local-server packets
On 1100 aironet - the same.
Can you help me?
irisrios Tue, 09/25/2007 - 07:09
  • Silver, 250 points or more
Add the statement encryption mode wep mandatory in the global command in the router. Because should have the encrytpion defined. But specifying the key is not mandatory. So you can skip the transmit key statement . This should be done for each Vlan you add.
_TDHster_ Wed, 09/26/2007 - 00:09
encryption mode wep mandatory - exist only at interface parameters, I've add it but nothing happens.
Exist any way to see debuggin information about errors due wireless negotiation/autentication?
