Consultative transfer appears to now be blind transferring..
davieshuw
I had consultative transfer working fine (CME).. but it now appears to have stopped working
My config is below. When I transfer a call it is blind transferred.. any ideas?
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
rchilcote
Your ephone-dns also need to be dual-line. I also recommend being more specific with the transfer-pattern command. For instance if your internal numbers are in the range of 3000 to 3999, use the transfer-pattern 3... command. This prevents the pause that may be there after transferring when only having the .T pattern.
rchilcote
It would appear that my dual-line is missing from all of my ephone-dn's. Ive replaced them and my consult is back. Thanks very much!!
