Configuring IDSM-2 in 7606
Sep 19th, 2007
I think when you install the IDSM in a 6500 you use VLANS. I am thinking about using the blade in a 7606, can you do similar task with interfaces? In other words how to you tell the blade what to look at if there are no vlans?
I am new to the IDS/IPS so any help or comments would be helpfull.
