AS5400 capacity
Paolo Bevilacqua Thu, 09/20/2007 - 00:19
Which exact 5400 model do you have ?
20 x T1 on a single box seems a bit high, you might consider getting a second router for the new circuits.
Maulik Shah Sun, 11/04/2007 - 07:22
The above is not doable because:
- the HPX has 7 slots in total
- you are using 1 for CT3 and 2 for 8CT1
- in the remaining 4 slots if you add DSP cards, you get 4 * 108 = 432 max
- Hence you can only go upto 432/24 = 18 T1s total
If you use the newer AS5400XM, this is doable, as that box has higher DSP densities per slot. I see there is a trade in program for this if you are interested:
Customers can use the Cisco Technology Migration Plan (TMP) to trade in products and receive credit toward the purchase of new Cisco equipment. For more information about Cisco TMP, go to http://www.cisco.com/go/tradein/. The Cisco TMP application requires all users to have a Cisco.com user ID.
