QOS on a 2600 - Question
Sep 19th, 2007
Hi All,
We would like to prioritize telnet traffic as well as our library system traffic. We would like to have all other traffic take up the rest of the bandwidth, and if telnet or library traffic isn't doing anything, then use up their allocation too.
Does the attached config look ok for the needed setup?
Thanks!
-Mike
Hieu Cao Wed, 09/19/2007 - 08:35
It looks fine to me, but why would you mark both traffic types as "ef". "EF" is mainly used to mark VoIP packets, so in your case I think you should mark them as "AF31" instead of "EF".
HTH,
hieu
chantman06 Wed, 09/19/2007 - 09:35
I had them marked as EF from a configuration example I found online. I'll change it to AF31. What does AF31 mean?
Thanks!
-Mike
Hieu Cao Wed, 09/19/2007 - 10:29
AF stands for "assured forwarding", low-drop class. AF31 is mainly used for mission-critical applictions or core business traffic.
There are tons of info on QoS and you can read more about it from the links below
http://www.cisco.com/en/US/tech/tk543/tk757/technologies_tech_note09186a00800949f2.shtml
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800c75d1.html
If you want to understand more indepth about QoS, check out this book ISBN 1587201240.
hth,
hieu
