bgp network advertisement
Sep 19th, 2007
I currently have the following in my router bgp section:
network 12.152.204.0 mask 255.255.254.0
I want to to change this so that it reads:
network 12.152.204.0 mask 255.255.255.0
network 12.152.205.0 mask 255.255.255.0
I also changed the routes from:
ip route 12.152.204.0 255.255.254.0 Null0
to this:
ip route 12.152.205.0 255.255.255.0 Null0
ip route 12.152.204.0 255.255.255.0 Null0
When I do this, my routes are not propogated for some reason. I want to put prepends on just one class c, but when I do with the first subnet, it prepends both class c's.
Tom
Richard Burts Wed, 09/19/2007 - 07:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Tom
Perhaps I am bit confused. In describing your issue you first say that the routes are not propagated. Then you say that it prepends both class Cs. How can it prepend if the routes are not propagated? Can you help me understand better what is going on?
Rick
tomswenson Wed, 09/19/2007 - 07:39
If I use the first network command with the 255.255.254.0 netmask, it propagates. When I split up the subnet into to class c networks, it doesn't propagate. I either want to not advertise out one class c at all or to be able to prepend just one class c, but so far, I can't do it.
Tom
Richard Burts Wed, 09/19/2007 - 08:01
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Tom
If you configure these statements:
no network 12.152.204.0 mask 255.255.254.0
no ip route 12.152.204.0 255.255.254.0 Null0
it should work.
You might want to clear your BGP neighbor relationships just to be sure.
Rick
tomswenson Wed, 09/19/2007 - 08:49
That is the thing, these are the changes I made and then it wouldn't propagate out my routes. I did clear my bgp with a soft out. If I test from Abovenet looking glass, it changes, but there is not route to my AS when I break this down by class c.
Tom
