LMS 2.6 email reports
Sep 19th, 2007
Can lms 2.6 email usertracking host reports and rme detailed device lists or do they only send email notifications?
Joe Clarke Wed, 09/19/2007 - 09:08
You can get email notifications when reports are available, but you will have to click on the links in the emails to view the reports.
joseph.filipek Thu, 09/20/2007 - 10:33
If lms 2.6 does not send the details of the user tracking database then how can lms be modified to regularily export the data via a script?
If by ut cli, we are using tacacs for authentication and when asked for password authorization fails.
Joe Clarke Thu, 09/20/2007 - 10:56
ut -cli should work even with TACACS+ authentication. You just need to make sure that the user credentials you are passing are correct in your TACACS+ server, and that the user is authorized to run UT reports. Exactly what error are you getting trying to run ut -cli?
joseph.filipek Thu, 09/20/2007 - 12:43
log4j:ERROR No appenders could be found for category (com.cisco.nm.ani.clients.u
log4j:ERROR Please initialize the log4j system properly.
Joe Clarke Thu, 09/20/2007 - 12:47
These are not true errors. They are harmless, and will not prevent one from running ut -cli reports.
joseph.filipek Thu, 09/20/2007 - 13:24
I am getting these messages before I can run ut reports and after I type the command:
Joe Clarke Thu, 09/20/2007 - 13:40
But these messages are not fatal. There must be something else you're seeing that is causing the ut -cli command not to run correctly. When I run ut -cli with local authentication, I get:
% ut -cli -u admin -p admin -query all
log4j:ERROR No appenders could be found for category (com.cisco.nm.ani.clients.utng.application.UTDataManager).
