SSH management on Outside interface
Sep 19th, 2007
I have a pix running 7.0.1 and I have configured ssh access on inside and outside interface. I have all of the settings the same on the interfaces.
If I connect it to the inside network I can connect via ssh, http or ASDM. When I connect it to the Outside I can only access it using HTTPS and the java ASDM applet. I can not connect ssh or ASDM client. and I do not get a ping response.
ssh is not disabled on corporate firewall because we cann ssh to other sites and ping sites like
I am trying to set this up so that I can ship it to a remote DR site and need to be able to manage across the Internet.
Thanks for any help.
wrwiii122 Fri, 09/28/2007 - 17:17
I was trying to do the same thing and couldnt get it to work. I found out that I cant see where to have a local ca server so I reverted back to the CLI. You have to input ca generate rsa key 1024 and then ssh will work.
Hope this helps.
