Terminal services program used in the lab
Sep 19th, 2007
Hi-
What terminal services program is used in the IE lab? (Putty, Secure shell, hypeterm, etc.) I figure it's better to train with the same equipment and applications I will be tested with.
Thanks in advance,
Troy
troystgermain Wed, 09/19/2007 - 09:16
Thanks for the reply.
That was almost 2 years ago, does anyone know if that is still the app used?
Thanks again,
Troy
stephen.stack Wed, 09/19/2007 - 12:11
Hope you don't mid if i jump in here. I too am looking to know what is used in the CCIE labs in terms of Terminal Software.
Also, i remember hearing a suggestion from a CCIE a while back stating that the keyboard is also important... And if one is preparing the labs then they should be at least using the correct keyboard to avoid typos in the exam... So in short
What Terminal App?
What Keyboard? (Europe)
What Windows Region?
Stephen
