4402 / guest network & FWSM
Sep 19th, 2007
4402 & FWSM
the wism & 4402 are running 4.1.171 code
The firewall switch is a 6500 dual sup720 dual FWSM
The building switch 6500 dual sup720's, WiSM
25 APs in this group right now.
wireless vlans 3 wep vlans, 1 guest vlan
vlan used
vlan600 wrls-mngmnt
vlan601-603 wrls-users
vlan604 wrls-guest
Trunk setup between the 4402 & the firewall switch all vlans trunked
All 5 vlans have been configured to the firewall group.
ALL DHCP handled on the 4402 all users utilize the external DNS. this includes the guest net.
The mobility tunnel between the WiSM & the 4402 is good. ping,eping,mping
all Wireless vlans are in the groups.
The 3 wep vlans work as expected and can bring up the expected web site,vpn connection
The Guest vlan doesn't work. The user connects gets thier DHCP information. when you check the DHCP info is looks good.
ping yourself, the address on the 4402 ( 192.168.138.252) but not the gateway.
open a browser and it starts to open the normal web page and dies. The redirect never happens. when you manually attempt to do it.
the redirect comes up the credentials are accepted and the redirect to the users home page doesn't happen. The user does get the small window stating the credentials were successfull but they can't go any further.
I have not seen much if any info on the cisco site for the 4402 & the FWMS let alone utilizing multiple wireless networks to the 4402 in the DMZ.
michael.lussier Fri, 10/05/2007 - 12:23
Issue was resolved on the 6500. Configuration error on the sup720 stopped the management untagged traffic from flowing.
Trending Topics - Security & Network
