Error bringing up MGCP Gateway
Sep 19th, 2007
I have a 2801 Router that gets the following error when I try to manually bring up mgcp:
Sep 19 20:36:04.753: ISDN Se0/1/0:23 **ERROR**: L2IF_SendPkt: idb is NULL
Sep 19 20:36:04.753: ISDN Se0/1/0:23 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
Has anyone seen this before?
1 vote
Overall Rating: 5 (7 ratings)
gogasca Thu, 09/20/2007 - 10:30
Hi Tom,
have you performed the Hard Loop Test to rule out hardware failure of the VWIC
Make sure no ACL are blocking MGCP traffic
and the following is configured.
interface serial0/1/0:23
isdn bind-l3 ccm-manager
tomrayjr Fri, 09/21/2007 - 05:28
I had not performed any loop tests (I have been lucky w/new hardware so that's generally the last thing I suspect). There are no alarms of any kind and the d-channel is up. The only difference in this site and my others is that the PRI is fractional (only 5 channels). I know 4.1(3) & MGCP do not 'support' this configuration and that may be the crux of my problem. I was expecting a different kind of error.
Aman Soi Tue, 11/17/2015 - 18:42
[+5]  to you.
I came across this issue and entering the isdn bind-l3 ccm-manager under serial interface resolved the issue.
