09-19-2007 01:08 PM - edited 03-09-2019 06:52 PM
I am trying to setup EZVPN to carry a GRE tunnel to a remote site so I can utilize EIGRP over this tunnel. The VPN is working fine however I can't get EZVPN remote to create any dynamic ACEs for my internal loopback for the GRE tunnel on the client side router. Any ideas on how to get a network that is not directly connected to the client PIX to show up in the EZVPN ACL?
The attached file provides a quick picture and configuration details.
09-25-2007 12:10 PM
Traffic can be routed from a VPN Client to the EzVPN server, then back out to another remote EzVPN server.
For configuring EzVPN Client and Server on the Same Router refer to
09-25-2007 12:17 PM
Both sides are using a PIX to run IPSec and that topology won't fit in here. But thanks for the suggestion.
