Cisco Unified Call Manager Express 4 w/NM-CUE
Sep 19th, 2007
Trying to call forward "ALL" calls from a 7970-G phone via softkey to a outside number over the FXO module. After AA answers and sends call to extension, the phone rings twice and then send the call to a womans voice, not sure where the womans voice is coming from. It does state that I "don't have to dial a one before calling this number".
It works fine if I send the local call out my long distance SIP provider, but I would rather not have all the local calls going out LD. I am trying to send out all 352 area code numbers and have 4 active incoming/outgoing lines for local calling to my direct PSTN.
Config below, Thanks for any suggestions but I can't figure this out and I know someone probabaly ran across this before.
PART OF THE CONFIG CISCO CONFIG:
translation-rule 9
Rule 0 ^90 0
Rule 1 ^91 1
Rule 2 ^92 2
Rule 3 ^93 3
Rule 4 ^94 4
Rule 5 ^95 5
Rule 6 ^96 6
Rule 7 ^97 7
Rule 8 ^98 8
Rule 9 ^99 9
voice-port 0/1/0
supervisory disconnect anytone
ring number 2
connection Tie-line 2001
caller-id enable type 2
voice-port 0/1/1
ring number 2
voice-port 0/1/2
ring number 2
voice-port 0/1/3
ring number 2
dial-peer voice 10 pots
destination-pattern 9352T
translate-outgoing called 9
port 0/1/0
forward-digits 7
dial-peer voice 11 pots
port 0/1/1
forward-digits 7
dial-peer voice 12 pots
port 0/1/2
forward-digits 7
dial-peer voice 13 pots
port 0/1/3
forward-digits 7
