stackable switch 3750 failed to save archive
Sep 19th, 2007
hi
i have 3750 stack switch and when i do archive it is failed and i have this message when i click fail archive.
"CM0056 Config fetch failed for <switch name> Cause: CM0204 Could not create
DeviceContext for 77 Cause: CM0206 Could not get the config transport implementation for <ip of switch>Cause: UNKNOWN Action: Check if required device packages are available
in RME. Action: Check if protocol is supported by device and required device package is installed."
i use transport setting in rme such as Telnet, TFTP, SSH in order. i can also telnet the switch from the LMS server.
anybody knows what's the cause? i am using LMS version 2.6. thanks
Joe Clarke Wed, 09/19/2007 - 19:39
Please provide the list of contents of the NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib/pkgs and NMSROOT/www/classpath/com/cisco/nm/xms/psu/pkgs/rme directories.
thetnaing00 Wed, 09/19/2007 - 21:42
hi,
i see 3750 zip file inside both directories.what more can i look for?my one is stack ones which combine 2 X 12- port 3750 and 1 X 24-port 3750. we use the same configuration,setting,ios version for all stack switches but only these two have problem of saving archive.thanks.
thetnaing00 Thu, 09/20/2007 - 22:32
hi,
any update for this?i tried a few times to get the archive configuration but no avail.i see 3750 zip package inside the folders. thanks
