Memory usage
Sep 19th, 2007
Would like to ask whether with the memory size of 205xxxx, usage is 203xxxx and the availability is only 19xxx. In a way is it healthy for the publisher server?
What are the main reasons of the high memory usage? If a CUOM is used, does it also play in this part? If so what is the best practise of the CUOM?
mchandak Thu, 09/20/2007 - 04:25
  • Gold, 750 points or more
With CUCM version 5.x onwards, yes this is normal, but if this is an earlier, version which uses Windows, then there is a problem and you should look at either adding more memory or resolving the issue.
As Gonzalo has mentioned, what is the CM version, How many devices are registered to the CM
alanhow2007 Sun, 09/23/2007 - 18:50
Thanks, for education Mchandak.
If we are using 5.1.2, what should be the right specification for the CPU utilized and Ram ?
Any Document states the specification for the CPU size and Ram size when upon usage of the system ?
