problem with ANIServer
Answered Question
I was having issues the crmdmgtd file, and had to reset the casuser password. After that daemon started succesfully, but ANIServer did not.
Here is the pdshow for the reference..
Process= ANIDbEngine
State = Program started - No mgt msgs received
Pid = 800
RC = 0
Signo = 0
Start = N/A
Stop = Not applicable
Core = Not applicable
Info = Service was already running
Process= ANIServer
State = Failed to run
Pid = 0
RC = -2
Signo = 1073741822
Start = N/A
Stop = 09/20/2007 08:26:50 AM
Info = Application failed or was registered incorrectly.
Please help me understand this and resovle...
Correct Answer by Martin Ermel about 9 years 8 months ago
good news!
but I am wondering how IPM blocked the reinit process for ani ...
You must not worry about the other processes. They will be started when they are needed as they are responsible for some tasks in LMS which can be configured to run periodically or which are used as periodic background processes.
Overall Rating: 5 (2 ratings)
David Stanford Thu, 09/20/2007 - 05:27
  • Cisco Employee,
Is the process EDS also running?
Can you try to stop ANIDbEngine via pdterm, then start it via pdexec and the same with ANIServer?
:\>pdshow EDS
Process= EDS
State = Running normally
Pid = 5056
RC = 0
Signo = 0
Start = 09/21/2007 08:40:03 AM
Info = Initialization complete
I did pdterm and pdexec, for both ANIDbEngine and ANIServer, but no luck..
Process= ANIServer
Pid = 0
RC = -2
Signo = 1073741822
Start = N/A
Stop = 09/21/2007 08:26:43 AM
Martin Ermel Mon, 09/24/2007 - 06:01
  • Blue, 1500 points or more
what gives "pdreg -l ANIServer"
please provide the complete output of "pdshow"
C:\>pdreg -l ANIServer
Process = ANIServer
Path = C:\PROGRA~1\CSCOpx\campus\jre\bin\java.exe
Flags = -Xbootclasspath:C:\PROGRA~1\CSCOpx\www\classpath\vbjorb.j
ar,C:\PROGRA~1\CSCOpx\campus\jre\lib\rt.jar,C:\PROGRA~1\CSCOpx\campus\jre\lib\i1
8n.jar -Xminf0.1 -Xmaxf0.1 -Djava.class.path=C:\PROGRA~1\CSCOpx\campus\www\class
path\jndi.jar,C:\PROGRA~1\CSCOpx\campus\www\classpath\providerutil.jar,C:\PROGRA
~1\CSCOpx\campus\www\classpath\dns.jar,C:\PROGRA~1\CSCOpx\campus\lib\classpath,C
:\PROGRA~1\CSCOpx\campus\www\classpath,C:\PROGRA~1\CSCOpx\lib\classpath,C:\PROGR
A~1\CSCOpx\www\classpath,C:\PROGRA~1\CSCOpx\lib\classpath\servlet.jar -Djava.lib
rary.path=C:\PROGRA~1\CSCOpx\bin,C:\PROGRA~1\CSCOpx\campus\bin -Dvbroker.orb.gcT
imeout=90 -Xrs -Xmx512m com.cisco.nm.ani.server.frontend.AniMain
Startup = Started automatically at boot.
Dependencies = EDS ANIDbEngine
Output of pdshow is attached...
Martin Ermel Tue, 09/25/2007 - 08:10
what happened on 9/25 around 8:40 am ? Some central DFM processes get stopped there. After you have reset casuser as Joe said, have you restarted the LMS processes? If yes, have you done it through the Web-Gui or CLI?
Martin Ermel Wed, 09/26/2007 - 07:46
Could you please stop the services with 'net stop crmdmgtd', check in TaskManager that every process has been stopped (no dbeng or dbsrv service anymore and no cwjava). Then restart with 'net start cromdmgtd'. After some time (around 10 min) get the output of 'pdshow' and please post it along with %NMSROOT%\log\ANIServer.log, where %NMSROOT% is the root install directory.
Martin Ermel Thu, 09/27/2007 - 01:53
I see this line:
ani ERROR DBConnection$ConnectionCreator: Failed to establish DB connectivity because: java.sql.SQLException: JZ00L: Login failed
along with a CORBA failure; I am not sure if the last is related to the first, so try to reset the ANI database password with the following procedure:
# Stop the processes again
net stop crmdmgtd
cd NMSROOT\bin
.\perl .\dbpasswd.pl dsn=ani npwd=
# enter the new password without the brackets
# restart the processes
net start crmdmgtd
# check if ANIServer is coming up now
pdshow ANIServer
here is the output...
C:\Program Files\CSCOpx\bin>.\perl .\dbpasswd.pl dsn=ani npwd=casuser
Start changing password for database 'ani'...
Starting database engine 'ani'
Starting database engine aniEng
ERROR: Failed to connect to database 'ani' with current password.
Trying the factory password for the database 'ani'.
ERROR: Failed to update new userinfo into database.
Stopping database engine aniEng
Unable to stop Adaptive Server Anywhere Agent -- Invalid user ID or password.
ERROR: Failed change password for database 'ani'.
Please see log file C:\PROGRA~1\CSCOpx\log\dbpwdChange.log for details.
i have attached the dbpwdChange.log.
output of pdshow is attached...
Also, i tried using reinitdb for reinitialize the ANIDb, but got following
C:\Program Files\CSCOpx\campus\bin>perl reinitdb.pl
This will erase all data from the database. Are you sure [y/n] ?y
START reinitdb...
Dropping database tables Wbu* ...
ani:::::Wbu
ERROR DropTable: Failed to establish DB connectivity because: java.sql.SQLExcept
ion: JZ006: Caught IOException: java.net.ConnectException: Connection refused: c
onnect
Reinitdb terminated with errors.
C:\Program Files\CSCOpx\campus\bin>perl reinitdb.pl -restore
This will restore your original database and your current data will be lost.
WARNING: Could not delete file C:\PROGRA~1\CSCOpx\databases\ani\ani.db
StandardDbRegistration .
ERROR: Failed to start database engine for database 'ani'
ani database initialization failed.
Martin Ermel Thu, 09/27/2007 - 23:48
Did you have verified that all LMS processes were down before using
C:\Program Files\CSCOpx\campus\bin>perl reinitdb.pl -restore ?
If yes, stop the prcocesses again and check if you have an ani.log file in NMSROOT\databases\ani. If it is there, remove it and execute in a dos box
NMSROOT\objects\db\win32\dbsrv7 -f ani.db
try restarting crmdmgtd.
If this still does not work or you do not have the ani.log file, do the following:
open the Windows services panel and change the 'Startup Type' for 'CiscoWorks Daemon Manager' from automatic to manual (do not change any other parameter for CiscoWorks related services! - I assume none of these parameters has been changed before), reboot your system and retry to reinit the ani db, if it is successful, reset the 'Startup Type' for the Daemon Manager to automatic, and start the processes (net start crmdmgtd).
If ANIServer and ANIDbEngine is still not running, please send the following file NMSROOT\www\classpath\cisco\nm\cmf\DBService\DBserver.properties
YESS.... Got it..
Apperently, there was something tied with IPM services... Because even i was following the process mentioned by Mermal, it was not letting me reinit the db. call it luck, or my frustration that i stopped all the IPM services as well, and , reinit the db with restore option. and here you go. Thanks God that now i have set a single password for all the db services...
I must say thanks to you Mermal,because i was on edge of reinstalling the whole server, but his help and guidance solved my problem..
Here is one more thing, so i might be aware of any consequences if there are any..
I have
AvTrimmer
ConfigChangeDetector
ConfigPurge
ConfigUpdate
EDS-TR
InvChangeDetector
which do not start atutomatically.. even if i start them manually, they get back to stop..
Is there any thing that i need to worry about, or is it something normal and avoidable?
Correct Answer
Martin Ermel Fri, 09/28/2007 - 01:38
good news!
