ASA Context running in parallel with ASA-VPN
Sep 19th, 2007
The scenario I have is an ASA in context mode and I am looking to terminate VPN clients on a seperate ASA that has an interface on the same private subnet. I have added a route to the ASA context for the VPN pool that belongs to the VPN-ASA. i can ping the vpn clients from the ASA context but I cannot establish any connection from the VPN client I get the following message
04:21:21 106001 Inbound TCP connection denied from to flags SYN ACK on interface inside
Any ideas? Thanks.
santukumar Mon, 09/24/2007 - 03:44
U have not cleared that u r talking about multiple mode.can u ping from outside to inside, if yes, then check ur vpn config i.e. check with this command---
show isakmp sa
show ipsec sa
And then see that vpn has been created or not.
natedog Thu, 09/27/2007 - 12:18
yes I am running one ASA in multiple context mode. The other ASA is running parallel in single context mode. The vpn terminates fine and I can ping the ipsec clients as they connect from the ASA that's running in multiple context mode. However if a vpn user tried to access internal resources its failing. This is the error I am getting which is related to translation problems. Inbound TCP connection denied from to flags SYN ACK on interface inside
umamytov Fri, 09/28/2007 - 19:16
It appears packet from server (SYN ACK from port 23 is certainly a server packet) to client is getting dropped. Since you said two ASAs are sitting in parallel can you clarify which ASA dropping the packet ? If it's multi context one then it appears routing needs to be fixed such that packets destined to VPN client IPs go to VPN-ASA. I would guess you have a L3 box on inside segment that routes to ASAs depending on destination. It may be that L3 box is routing VPN client IPs to multi-ASA instead of VPN-ASA.
natedog Sat, 09/29/2007 - 05:51
Right now I am not using any layer 3 box, i was hoping to avoid that and just have the multi-contxt ASA send packets over to the ASA-VPN device when they needed route out.
I have tried utilizing the NO_NAT rules on both the VPN-ASA and context ASA but since the traffic is never leaving the inside interface of the context ASA then that doesnt make any sense.
Am I going to need a layer 3 box to handle this?
