E1 data interface for 2600
Sep 20th, 2007
Hi all. First of all sorry for my bad English.
We have a CISCO2600 router and we're planning to contract to our data provider (Telefonica Espa?a) one ISDN PRI connection. We only need this connection to carry data and not voice and I like to know wich card we need to adquire.
We only need 2 Mb simmetric data connection, without channel separation or anything else.
Thanks in advance.
Overall Rating: 5 (2 ratings)
vaisharm Thu, 09/20/2007 - 00:32
Hi Toni,
Please see this:
Cisco 2600 Series - Relevant Interfaces and Modules
Looks like these are your options:
NM-1CE1T1-PRI 1-Port Channelized T1 / E1 Modules with PRI Network Modules
NM-1CE1B 1-Port Channelized E1/ISDN-PRI Balanced Network Module
NM-1CE1U 1-Port Channelized E1/ISDN-PRI Unbalanced Network Module
Paolo Bevilacqua Thu, 09/20/2007 - 00:33
If you mean ISDN PRI like the service in which you have atelephone number, and remotes also with ISDN do dial-up for a 64 or 128 Kbps switched circuits, them yes you will have channel separation and exactly up to 30 of them.
The card to use is NM-1CE1B or NM-1CE1T1.
The same card can be used also for non-ISDN, that is, point-to-point, clear-channel circuit of up to 30 timeslots.
toni_mart Thu, 09/20/2007 - 01:04
It helps a lot, but I have a final question.
Can't I use VWIC-1MFT-E1 card?
Thank you
Paolo Bevilacqua Thu, 09/20/2007 - 01:11
For T1 or E1 PRI service, yes. Note some dial-up features, not important for many, are not supported with the VWIC. But if you plan to upgrade like to a 2801 in the future, a VWIC would be better as it is a newer ans smaller module.
Please remember to rate useful posts!
toni_mart Thu, 09/20/2007 - 01:19
Thank you very much!!
Question solved! I think we'll buy VWIC cause it's smaller and we only need data service not other services.
Thank you and goodbye.
