CCM 6 AXL getPhone: A syntax error has occurred
Sep 20th, 2007
Hi all.
I've been playing al while to solve the error I receive useing axl getPhone to Cisco Call Manager 6 (6.0.1.2000-4)
I'm developing in Visual Studio 2005, C# and imported the wdsl file fom the axl toolkit.
Here is al sample code I use:
System.Net.ServicePointManager.CertificatePolicy = new BruteForcePolicy();
System.Net.ServicePointManager.Expect100Continue = false;
AXLAPIService axlApi = new XLAPIService();
axlApi.Credentials = new System.Net.NetworkCredential("user", "pass");
axlApi.SoapVersion = System.Web.Services.Protocols.SoapProtocolVersion.Soap11;
axlApi.Url = "https://ccm-ip:8443/axl/";
GetPhoneReq getPhone = new GetPhoneReq();
getPhone.ItemElementName = ItemChoiceType29.phoneName;
getPhone.Item = "SEP000AB7144897";
GetPhoneRes getPhoneRes = axlApi.getPhone(getPhone);
On the last line I recieve an "A syntax error has occurred" error. When I look into the trace logs from the callmanager I see the following:
2007-09-20 11:23:44,075 INFO [http-8443-Processor17] axl.AxlListener - <?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Body><getPhone xmlns="http://www.cisco.com/AXL/API/6.0"><phoneName xmlns="">SEP000AB7144897</phoneName></getPhone></soap:Body></soap:Envelope>
2007-09-20 11:23:44,090 INFO [http-8443-Processor17] axl.Handler - Handler initializing
2007-09-20 11:23:44,198 ERROR [http-8443-Processor17] axl.Handler - [email protected]
java.sql.SQLException: A syntax error has occurred.
at com.informix.util.IfxErrMsg.getSQLException(IfxErrMsg.java:395)
... etc.
I noticed the following line:
<phoneName xmlns=""> Could this cause the syntax error? Or does anyone see anything else what might cause this problem.
Thanks in advance for any support!
Mike-1985 Tue, 09/25/2007 - 04:30
How could I change this? I've been looking in the generated code (reference.cs), but could not find any 'xmlns' or anything else what might be hulpfull.
Anyone?
