sending syslog message on logon
Answered Question
Sep 20th, 2007
Hi forum,
How do I configure the syslog to send message when user logon to the router, either success or fail.
Thanks much,
paul
Correct Answer by yjdabear about 9 years 8 months ago
Do you have the pre-requisite "login block-for seconds attempts tries within seconds" configured, as specified in this section? I'm not sure how "log on-success ..." worked if the above were not configured.
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080455b93.html#wp1027195
Also, according to this document
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hsec_c/part30/h_login.htm
"Logging messages for failed login attempts are automatically enabled when the auto secure command is issued; they are not automatically enabled for successful login attempts via autosecure."
Overall Rating: 5 (2 ratings)
paulnigel Thu, 09/20/2007 - 17:41
Thank you very much yjdabear,
This solves my problem!
Thanks much,
PN
paulnigel Mon, 09/24/2007 - 16:14
Hi Yjdabear,
I am able to log the success logon, but i cant log the failure logon, i use this command:
login on-failure log
login on-success log
but i only get this:
%SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user:
anything that I must look out for?
Thanks much,
PN
yjdabear Mon, 09/24/2007 - 20:13
  • Gold, 750 points or more
Are the failures showing up with "show login" or "show login failures"?
paulnigel Mon, 09/24/2007 - 20:27
Hi yjdabear,
when I issue sh login failures, i get this result, actually i tried with failed attempts to test, therefore it cant be true:
sh login failures
*** No logged failed login attempts with the device.***
I am actually login to a remote syslog server.
Thanks much,
paul
Correct Answer
yjdabear Tue, 09/25/2007 - 07:01
paulnigel Tue, 09/25/2007 - 17:05
Hi Yjdabear,
You are indeed very helpful. yes you are right, it works now!
Thanks much,
Pnigel
