ISDN BRI backup - Disconnect after 1 sec
Sep 20th, 2007
There is a ISDN BRI backup to Serial IF on a router.BRI seems to be able to cennect with opossite site, but after 1 sec comes Disconnect(see attachment).I tried Floating static routes and Dialer watch as well, with the same result. Can anybode help me? Thanks
Kevin Dorrell Thu, 09/20/2007 - 03:06
The problem seems to be in this section:
*Sep 20 09:21:29.035: Di0 IPCP: O CONFREQ [Closed] id 1 len 10
*Sep 20 09:21:29.035: Di0 IPCP: Address 10.235.32.5 (0x03060AEB2005)
*Sep 20 09:21:29.035: Di0 PPP: Process pending ncp packets
*Sep 20 09:21:29.035: BR0/1/0:1 PPP: Process pending ncp packets
*Sep 20 09:21:29.047: BR0/1/0:1 LCP: I TERMREQ [Open] id 148 len 4
*Sep 20 09:21:29.047: BR0/1/0:1 LCP: O TERMACK [Open] id 148 len 4
*Sep 20 09:21:29.047: BR0/1/0:1 PPP: Sending Acct Event[Down] id[26]
*Sep 20 09:21:29.047: BR0/1/0:1 PPP: Phase is TERMINATING
*Sep 20 09:21:29.047: Di0 PPP: Sending Acct Event[Down] id[27]
*Sep 20 09:21:29.047: Di0 IPCP: State is Closed
What is the IP address at the other end?
Kevin Dorrell
Luxembourg
richard.turian@... Thu, 09/20/2007 - 03:38
IP address of Local Dialer0 (calling) is:
10.235.32.5/30
IP address of Remote Dialer0 (called) is:
10.235.32.6/30
smothuku Thu, 09/20/2007 - 04:02
Hi Richard ,
Please configure ppp chap host name XXXX under dialer 0 on both sides ...
Whenever isdn is disconnecting after sometime it could be problem with authentication configured on routers.
Please check the username and password configured on both ends.If possible configue it once again...
plz paste sh isdn status output .
satish
pciaccio Thu, 09/20/2007 - 04:08
One thing you can check also is if you are running AAA on both routers. Do you have any AAA statements refering to remote PPP authentication.. Your posting only showed the configs for the interfaces... Can you supply a more comprehensive configuration for review....Thanks...
richard.turian@... Thu, 09/20/2007 - 05:14
There is no aaa new-model statment on both side.I`ve rewrite user/psw and added ppp chap hostname ... command.
output of isdn status follows:
cpp-poprad#
Sep 20 14:52:00.647: %DIALER-6-BIND: Interface BR0/1/0:1 bound to profile Di0
Sep 20 14:52:00.651: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to up
Sep 20 14:52:00.651: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 0524684841 N/A
Sep 20 14:52:01.655: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 0524684841 cpp-poprad
Sep 20 14:52:01.655: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1 disconnected from 0524684841 cpp-poprad, call lasted 1 seconds
Sep 20 14:52:01.659: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to down
Sep 20 14:52:01.659: %DIALER-6-UNBIND: Interface BR0/1/0:1 unbound from profile Di0sh isdn statu
Global ISDN Switchtype = basic-net3
ISDN BRI0/1/0 interface
dsl 2, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 71, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 2 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
cpp-poprad#sh isdn act
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
cpp-poprad#
Sep 20 14:52:18.295: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to up
Sep 20 14:52:18.295: %DIALER-6-BIND: Interface BR0/1/0:1 bound to profile Di0
Sep 20 14:52:18.299: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 05246848411 N/A
Sep 20 14:52:18.351: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 05246848411 cpp-poprad
Sep 20 14:52:18.531: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to down
Sep 20 14:52:18.531: %DIALER-6-UNBIND: Interface BR0/1/0:1 unbound from profile Di0sh isdn act
pciaccio Thu, 09/20/2007 - 06:19
This is kind of a stupid question, but I see that your ISDN switch type is Basic-Net3. I have seen in the past that the wrong switch type has been inputted and the call actually goes out but does not stay up. Can you re-verify that your switch type is correct. Just something to check....Thanks...
richard.turian@... Thu, 09/20/2007 - 21:55
The ISDN switch type is net3 on both sides as configured. Simultaneously i`ve configured second backup link on another pair of routers, one side net3, oposite side net5 - and it start working immediately. So the problem is maybe IOS version.
