VPN Client problem
Sep 20th, 2007
Hi there,
I have configured a remote access VPN for a customer which has a BT router at home.
The BT router assigns an address in the DHCP pool 192.168.1.0/24 to the customers laptop.
The VPN assigns an address in the VPN pool 192.168.100.0/24.
The 192.168.1.0/24 is also a subnet on his internal LAN.
Now, I believe that this 192.168.1.0/24 might be the problem why the customer can only access the internal network and not the Internet (I have split tunneling enabled).
I have asked the customer to change either of the sites but he says that there must be another solution.
Does anyone know of any other solution? I am using NAT transparency because there are too many servers on the internal network to use static NAT through the VPN.
Thanks in advance.
P
Overall Rating: 5 (1 ratings)
mfreijser Thu, 09/20/2007 - 04:54
  • Bronze, 100 points or more
This is a problem that i'm starting to see more often; same subnets in use at home-users and the corporate LAN.
I personally have found no solution for this problem, for as far as i know is this only possible with a LAN-2-LAN tunnel. See the following page for the solution for the same problem with a LAN-2-LAN tunnel:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800b07ed.shtml
Michael
