unable to add a 3750G-24T in a existing stack
Sep 20th, 2007
when i tried to add a 3750 in an existing stack i've got 2 stack.
what should be the state of stackwise port reported by the cmde sh switch stack-port
the cmde report some down port on my stack
In a working state the ports should be up. It is worth checking that the new switch is provisioned within the config of the stack, and that they are all running the same SDM template, and have the compatible IOS versions. I would expect to see warnings about version mismatch and SDM template mismatch within the output of a show switch command.
a.diot Thu, 09/20/2007 - 06:26
thanks for answering , the version is the same on all switch (12.2.40 ipservices)
here are the results of cmd sh switch stack-port (4th switch removed)
sumatra#sh switch stack-port
Switch # Port 1 Port 2
1 Down Ok
2 Ok Down
3 Ok Ok
is that normal?? or should i 've OK for all ??
regards
glen.grant Thu, 09/20/2007 - 12:09
  • Purple, 4500 points or more
Post a show version" and a "show switch detail" . Looks like a problem with at least 2 of your switches are not working . Usually a version mismatch or something like that .
a.diot Thu, 09/20/2007 - 23:20
i glen thanks for answer
here is a show platform stack-manag all
sumatra#sh platform stack-manager all
Switch/Stack Mac Address : 000f.340f.3180
H/W Current
Switch# Role Mac Address Priority Version State
1 Member 000d.290a.3a00 10 0 Ready
2 Member 000d.2926.4500 12 0 Ready
*3 Master 000f.340f.3180 15 0 Ready
4 Member 0000.0000.0000 0 0 Provisioned
Stack Port Status Neighbors
Switch# Port 1 Port 2 Port 1 Port 2
1 Down Ok None 3
2 Ok Down 3 None
3 Ok Ok 1 2
Stack Discovery Protocol View
Switch Active Role Current Sequence Dirty
Number State Number Bit
1 TRUE Member Ready 029 FALSE
2 TRUE Member Ready 029 FALSE
3 TRUE Master Ready 131 FALSE
Stack State Machine View
Switch Master/ Mac Address Version Current
Number Member (maj.min) State
1 Member 000d.290a.3a00 1.36 Ready
2 Member 000d.2926.4500 1.36 Ready
3 Master 000f.340f.3180 1.36 Ready
Last Conflict Parameters
Switch Master/ Cfgd Default Image H/W # of Mac Address
Number Member Prio Config Type Prio Members
1 Member 10 No 5 2 0 000d.290a.3a00
2 Member 12 No 5 2 0 000d.2926.4500
3 Member 15 No 5 2 0 000f.340f.3180
Pavel Bykov Fri, 09/21/2007 - 00:01
  • Silver, 250 points or more
1. Is the problem only between stack members 1 and 2?
2. (banality) Have you tried different stack cable?
3. I've seen this problem before, when the loop was not able to close, and one stack connection was always going down. But I think it was a hardware issue.
There is a requirement for switches to have the same SDM template, but with different SDM you wouldn't even be able to create a stack.
I'd try to disconnect member 3 and see if stack between 1 and 2 comes up.
glen.grant Fri, 09/21/2007 - 03:22
How is the stack wired ? Normally it should go from port 1 on the first switch to port 2 on the 2nd switch and port 1 on the 2nd switch to port 2 on the third switch and port 1 on the 3rd switch should go up to port 2 on the first switch .
