ASA - DHCP options not passed when dhcprelay enabled
Sep 20th, 2007
Hi all,
I have an ASA5510 which serves as an DHCP relay for L2TP/IPSec VPN Clients. The VPN clients connect to a CVPN3005 concentrator on one off the dmz segments on the ASA. The concentrator then does a DHCP request for the client to an DHCP server on the inside network.
The problem is: I get an IP address but none of the DHCP options (classless routes, DNS servers, domainname).
I had the same configuration with running with a PIX515 and all worked well.
Can anyone tell me what the problem is?
Regards, Frank
fembsen Thu, 09/27/2007 - 00:03
Thanx for the reply!
However in our config the ASA only acts as a DHCP relay. It passes DHCP requests from the CVPN3005 on a DMZ interface to a DHCP server on the inside network.
The vpn-addr-assign command is, as far as I know, only used when client VPN's are terminated on the ASA itself which is not the case here. Remember: I get an DHCP address but not the, in the scope specified, DHCP options.
Could it be that I have to set 'dhcpd auto_config'? Is this a global DHCP option which is used by 'dhcpd' as well as 'dhcprelay'?
regards, Frank
