Interface service policy - is this right?
Sep 20th, 2007
I have a service policy configured on a 2MB serial interface on a 2620, policy-map is as follows:
policy-map queue
class critical
priority 204
set ip dscp ef
class priority
bandwidth percent 80
class class-default
fair-queue
random-detect dscp-based
set ip dscp default
I have max-reserved-bandwidth of 100%. As I have reserved 90% (10% for critical and 80% for priority), I would expect to see a further 10% (204kbps) as being available. I use this same policy on 3 other routers, all to that result.
However, when I do a show run int, I see that 1844kbps are still available:
Serial0/0 is up, line protocol is up
Hardware is PowerQUICC Serial
Internet address is x.x.x.x/30
MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec,
reliability 255/255, txload 181/255, rxload 31/255
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input 00:00:01, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 101787
Queueing strategy: weighted fair
Output queue: 0/1000/64/101603 (size/max total/threshold/drops)
Conversations 0/50/256 (active/max active/max total)
Reserved Conversations 1/1 (allocated/max allocated)
Available Bandwidth 1844 kilobits/sec
5 minute input rate 251000 bits/sec, 362 packets/sec
5 minute output rate 1457000 bits/sec, 311 packets/sec
738303666 packets input, 4012471098 bytes, 0 no buffer
Received 846788 broadcasts, 0 runts, 0 giants, 0 throttles
10 input errors, 0 CRC, 8 frame, 0 overrun, 0 ignored, 2 abort
599171675 packets output, 2803364940 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
What's going on here, or is this a normal way of representing for a 2620? My 2800's represent it as 204/10% as expected.
Any one can shed light on this it would be much appreciated! Thanks.
r1#show policy-map int
Serial0/0
Service-policy output: queue
Class-map: critical (match-any)
566218 packets, 38772726 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group 181
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 204 (kbps) Burst 5100 (Bytes)
(pkts matched/bytes matched) 326895/21815708
(total drops/bytes drops) 0/0
QoS Set
dscp ef
Packets marked 566218
Class-map: priority (match-any)
7705221 packets, 3601939397 bytes
5 minute offered rate 715000 bps, drop rate 0 bps
Match: access-group 180
7705213 packets, 3601939455 bytes
5 minute rate 715000 bps
Queueing
Output Queue: Conversation 265
Bandwidth 80 (%) Max Threshold 64 (packets)
(pkts matched/bytes matched) 5162685/2786697189
(depth/total drops/no-buffer drops) 2/13549/0
Class-map: class-default (match-any)
3082096 packets, 3741578423 bytes
5 minute offered rate 1085000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 12/738/0
exponential weight: 9
Overall Rating: 5 (1 ratings)
Pavel Bykov Thu, 09/20/2007 - 05:54
Yes, it's supposed to say what you are expecting. What IOS does it run? I have encountered some significant problems on older IOS releases.
On the other hand, it displays 2048-204=1844 Kbps. So it seems it's substracting only priority bandwidth. Try typing "bandwidth 1638" instead of "bandwidth percent 80".
But hey, this is not an important idicator of your qos. Importnat output is that of a "show policy-map interface X/X" command. I think you can safely ignore that message if your QoS functions as desired.
hope this helps
jigsaw2026 Thu, 09/20/2007 - 06:08
Thank you for your response, you have confirmed my thoughts. I think I will concentrate on policy-map int output instead.
It's running 12.1(3r)T2, so this could be a factor.
J
