snmpset TruthValue question
Sep 20th, 2007
hello,
I have the following MIB object:
cdot11SecAuxSsidAuthEnabled OBJECT-TYPE
SYNTAX TruthValue
MAX-ACCESS read-write
STATUS current
root@teo:/home/teo# snmpwalk -v 2c -c demopublic 192.168.1.11 CISCO-DOT11-SSID-SECURITY-MIB::cdot11SecAuxSsidAuthEnabledCISCO-DOT11-SSID-SECURITY-MIB::cdot11SecAuxSsidAuthEnabled."gstam-cisco".1 = INTEGER: true(1)
CISCO-DOT11-SSID-SECURITY-MIB::cdot11SecAuxSsidAuthEnabled."gstam-cisco".2 = INTEGER: false(2)
CISCO-DOT11-SSID-SECURITY-MIB::cdot11SecAuxSsidAuthEnabled."gstam-cisco".3 = INTEGER: false(2)
how can i write a false value to the following object?
i have tried this but it doesnt work:
snmpset -v 2c -c demopublic 192.168.1.11 CISCO-DOT11-SSID-SECURITY-MIB::cdot11SecAuxSsidAuthEnabled."gstam-cisco".1 = 2
CISCO-DOT11-SSID-SECURITY-MIB::cdot11SecAuxSsidAuthEnabled.gstam-cisco.1: Unknown Object Identifier (Index out of range: gstam-cisco (cdot11SecAuxSsid))
David Stanford Tue, 09/25/2007 - 06:55
  • Cisco Employee,
You might have to change your syntax and specify that it is an integer type...not sure what your snmp util is
ex)
snmpset -v 2c private 192.168.1.11 cdot11SecAuxSsidAuthEnabled.1 integer 1
theodionys Tue, 09/25/2007 - 07:02
snmpset -v 2c private 192.168.1.11 cdot11SecAuxSsidAuthEnabled.1 i 1
thanks !!!
Trending Topics - Security & Network
