cm 4.09 topology map problem
Sep 20th, 2007
I installed the CM 4.09 patch which caused problems . The following TAC CSCsk08540 was identified by forum. I installed the supposed patch. After it my topology map had new links between devices. The serial bus icons is appeared between devices instead of single links.
I deleted them but they appeared again after discovery.
How can i achieve that there will be single link icon between devices?
Overall Rating: 4 (1 ratings)
Martin Ermel Mon, 09/24/2007 - 05:57
as a test do the following:
open the topology map and select two devices between which the problem appears, delete these 2 devices from the map, next select a neighbour device for each of the deleted devices and run a Data Collection on them,the deleted devices should reappear
if the Data Collection will not bring the devices back, start a discovery - this should list the 2 devices then start a data collection on these new devices
will now the connections be displayed correctly?
KAROLY KOHEGYI Mon, 09/24/2007 - 06:25
hi ,
Thank for infos.
It may help but we have 400 devices and 1-2 hundred serial bus icons.
There are star topology between branches.
May be i will delete all ani databases :-(((
Why does CM draw serial bus between devices ??
KAROLY KOHEGYI Thu, 10/04/2007 - 00:17
The method what you supposed helped us .
It was not a nice method but useful.
There wa sa large, hard work to redraw, relayout nearly the all map,
