Dialup users getting fixed IP addresses from a router
Sep 20th, 2007
Is it possible to configure a router with local user database and provide static addresses to remote dialup clients based on username in the local database. This is a standalone 2800 solution with primary rate ISDN and Digital onboard modem module.
I know this is possible using external Radius / Tacacs
Thanks & regards,
Mark
Overall Rating: 4.7 (1 ratings)
paolo bevilacqua Mon, 09/24/2007 - 11:04
  • Hall of Fame,
    Founding Member
You can have them authenticate in tty mode and then start autocommand ppp for each different user as optionfor username command, for each specifying the ip address to use.
markturner Tue, 09/25/2007 - 00:44
Thanks for your feedback. Does this mean the client would have to bring up their terminal window as part of their windows setup to authenticate first. Not sure if the client will go for this one..
Mark
paolo bevilacqua Tue, 09/25/2007 - 11:36
  • Hall of Fame,
    Founding Member
Yes. Then I don't know of a way of doing it w/o radius or tacacs.
markturner Wed, 09/26/2007 - 00:50
Thanks guys.... I have another question about allocating an IP address on the same range as the LAN side.
e.g. LAN address of the router 10.0.0.1 255.255.0.0 the client must have e.g. 10.0.0.10 /32 etc.
Has anyone done this before ?
markturner Wed, 09/26/2007 - 06:25
Thanks Aaron,
Wilk chck this out at the weekend...
Best regards,
Mark
paolo bevilacqua Wed, 09/26/2007 - 01:47
  • Hall of Fame,
    Founding Member
Great suggestions Aaron.
All is well. we still here making things work.
best of luck!
